I am sure this has been covered (just not seeing it) but has anyone tryed to run a booster fuel pump??
Comming from gassers (turbos and superchargers) we use to run a pumps that would come on at a certain boost level so fuel would be delivered no matter what.
I have considered putting on a pusher pump, but don't like alot of noise and know that most of them don't last alot of miles. But if the pump only came on when needed (maybe like 20 psi boost) then I could easily lived with the noise and the life span would be greatly increased.
So anyone have a set up like this??? Anyone using a gas type pump for it???
Or another route would be to have the trigger run off the fuel pressure side and if it dropps below XX psi then the aux pump would kick on... .
Thanks in advance.
Dave
Thanks in advance.
Dave
