Adj Cam Sensor & BDDL Power Pup??
comments on ATS trannies
Quad race box and codes P0192-P0237
Roktech's site doesn't say anything about this combo.
Anyone using this combo?
If BDDL already adds some timing (BD web-site doesn't say how much and what setting), is it a waste of $$$?
I don't know.
Send an email to Bullydog, maybe they'll tell you. :-laf
Stacking boxes is not the same as adding a sensor that will change timing but only static.
Boxes will do variable timing, duration, pressure etc. And some combinations seem to work better than others.
I did the tone wheel mod with mine and my BDDL on the tow setting stacked with a VA C3. 1 on the middle setting (All my poor stock clutch can handle. ). It seemed a bit much for my combo. I backed the tone wheel back off to about the half way point and all is good again. Engine seemed to struggle a bit with all that advance on top of what the BDDL gives me. Actually lost a little bottom end and MPG until I backed it off. Hope this helps...
100 Proof
