Adjust IDLE
94-98.5 parts into a 89-93 question
10 wheeler 1st gen.
Hey Guys, so i have turned up the power screw, and now my idle has increased is there a way to turn down the idle without re adjusting the power screw.
Yes, there is screw on the back side of the AFC housing its long and thin with a 10mm jam nut on the back end and the throttle linkage rest on the other end, you need to turn that screw out and it will back off the throttle and lower your idle.
Take a Flat blade screwdriver and tap the nut loose then take a small bladed flat blade screw driver and turn the idle screw counter clock wise . Hope that help's that jam nut is a Pain to get with a wrench so that is why I use a screwdriver and small hammer .
