Same thing here. I found two holes in the top of the fender when I raised the hood. The holes are marked with stamped arrows. (Mine's a '14 Laramie) The up and down adjustment is in the most forward hole closest to the radiator. You need a 7mm socket with a 4" extension. Rotate the screw ccw to lower the beam, cw to raise it. I just did that yesterday, and have not tried it out yet in the dark, just lowered each side exactly one turn to see what happens. Haven't messed with the fog lights yet, but they have a plastic knob type adjustment behind them someplace.
