adjusting head lights
Heat/air fan blows but no air comes out
American Force Super Singles
i put a 2" rear block on and now i have to adjust the front light a bit to make up for it - does anyone know where the adjustment is ? or a picture of it ? i looked in my manual but it dozen't t say anything for that - let me know :confused:
I have an 07 with no lift, but the headlights are out of wack from the factory. I also can't seem to figure out how to adjust them???
There is an ajustment torq screw on the inside of the headlight fixture. On mine the only ajustment is up/down. Just open the hood and look on the engine side of the headlight assembly. You will see the bolt casing.
please spend the 15. 00 to 20. 00 bucks to have them properly adjusted and help save all of our eyes thank you
Boy you sure would be MAD if I came up on you!! LOL!! With 12 inches of lift (with tires), my headlights are a bit off!! LOL!! The high beams are pretty much useless and I drive around with low beams and driving lights on. I plan on adjusting them but just don't have the time. they do work well for crawling up on someone ie punk ricer POS that has cut you off:mad: , just crawl up on them and if I get a good spot, I can get all 3 mirrors and they can't run from the lights :-laf
WELL I ADJUSTED THE HEADLIGHTS AND THE FOGLIGHTS - NOW ITS ALOT BETTER - VERY EASY TO DO. ;)
