The boost you are seeing is where it should be. Piers sets these turbos not to exceed 38 psi and if you take it higher you probably are your own warranty station. Also trust me when I say that you really are NOT going to get more HP from boost higher than 38 psi from a HX-40, the heat and backpressure derived from the higher boost more than offset the higher charge number.
Doug
