Engine/Transmission (1998.5 - 2002) adjustment of twins wastegate towing 2500#s
Engine/Transmission (1998.5 - 2002) Need Help With Fuel Leak
2nd Gen Non-Engine/Transmission ABS fault at slow speeds
:confused: how would one adj. the W/g for towing with a Piers HX-40 H3TB set of twins. beleive it or not i am running a set of "stock" ho inj. lengthen the W/G rod ?any help will be greatly apprecaited.
Just hook the 40 wastegate to the 3b pipe. That way the 40 will boost until the 3b makes enough boost to open the gate of the 40. Should work. If it doesn't, unhook the wastegate arm and turn the end piece on the actuator rod in about 1 turn. It may take more than that. Mite have to play with it to get it working rite.
