Adobe Acrobat
Need ADVISE/HELP on home/farm ELECTRICAL ISSUE
LOOK out Bob Wagner...
I have the full version of Acrobat so if you just have the reader I don't know if this is possible but you can give it a try.
If you click on Document then Pages then Extract you can remove pages from the file you have open and delete the rest.
If the file was 40 pages long you could extract the first 20 pages and send them then extract the second 20 pages and send them seperately.
This might be a little clumsy, but it should work. There is a free program called pdf995. I can't remember where I got it so you will need to use Google. This thing installs as a printer. If you select it as your printer it will create a PDF file with the print output. In this case print your file in halves to pdf995. The result will be two PDF files.
How big is the file? You could send it to me and I'll split it. -- email address removed --
