So I finally got an Adrenaline yay! Except for a few minor details. First got the box on Tuesday. A friend and me put it on on Wednsday after work. Everything was fine until I hooked the Red W/ white tracer up to the #9 fuse. The circuit had power immediatly. Start engine up nothing. The pulse was dead. Tried to shut engine off and it won't quit. Tap brake accelerator nothing. finally had to pull the #9 fuse to kill the engine. It was getting dark and late so I just unhooked that wire and drove it home. Thursday I didn't get a chance to look at it.
Friday rolls around and so I download a few tunes to try and get stuff working. I upload 1018 into the box. Didn't start it but the engine circuit had power as soon as I hooked the fuse tap to it. So I tried 1000B same thing. Went back to the 1018 for a bit and then I tried to start the truck. It won't start.
About this time I figured out what was wrong with the pulse. When I took it apart to fish it through the firewall I didn't make sure the pins were all the way seated when I put it back together. So now it works at least.
Took the Adrenaline off the truck and it still won't start. Disconnected the batteries for about 30 min and the reconnected them. no change. It's throwing a 1475 code. Called Quad and they want me to tow it into the dealership and send the box back to them to check it.
About the only thing I can think of is to let it sit overnight without the batteries and hope it helps? Anybody else have any ideas?
