Engine/Transmission (1998.5 - 2002) adrenaline w/smarty
Engine/Transmission (1994 - 1998) Turbo impellershaft play
Engine/Transmission (1998.5 - 2002) Stock Boost Pressure
anybody running this? The reason is, got a dyno run on the 10th and can't decide if we want to stack the smarty with the adrenaline or just run the adrenaline with the dyno program. Suppose to get the adrenaline monday or tuesday, but the clutch is bad so probably won't get much time to mess with it until we get the clutch in on thursday, just wondering what people are doing since we really can't do any testing.
By the way its a 01, 5 speed, 150hp injectors, gdp pump, SO injection pump
Thanks
If you had a bigger turbo I would say to stack it. Since you don't, I think you will just be putting out the fires a little with too much fuel.
