Engine/Transmission (1994 - 1998) Adv timing, easy?
Looking for insturctions to advance timing and wondering the tools and skill level needed. Can any fool do it or do you need to be a master mechanic, I can fall on either end depending on the day.
Check out the FAQ section (at the top of the 12v engine/trans. section) there should be a post there that will answer all your questions.
Nathan
If you like a challenge, are mechanically inclined, have a little time and don't mind buying some tools, I'd say go for it! I just completed the following on Wednesday:
advanced timing to 16
valve adjustment
tap kdp
new serpentine belt as I put it all back together.
I couldn't be happier. It was a whole lot easier finding TDC with the timing gear cover off. I was able to avoid the whole timing pin ordeal. I read on this for at least a month before jumping in. Never regret it!
About a week ago I installed the 3k gsk, moved the afc forward and discovered I have a #8 that was full back. No wonder I couldn't get any fuel. :( It's pretty amazing w/ the plate in the middle, really strong. Gotta take it easy til I get a DTT... . it's always something. :D Opening the pump like that was pretty spooky at first, but was a great experience and am REALLY glad I jumped in. Be patient, have lots of documentation and you'll do great!
For tools: I picked up a couple good torque wrenches off ebay. I bought the 'timing kit' (SP500, I think) and feeler guages from snap-on. Having the right tools for the job makes all the difference.
Hvy
AZ,
One thing I didn't mention is the barring tool. I can't imagine doing this without it. I got one from snap-on, it was ~$50. Kinda steep but worth it. It's really nice if you have a bunch of 3/8" extensions w/ wobbles and/or u-joints. I was able to turn the motor from up top at the radiator. Air ratchet was good for going around the horn.
Happy new year, and best of luck,
Hvy
