Advanced Timing Questions
RADIO 1994
Incurable Rear brake shudder solved?
I'm contemplating advancing my timing to 14. 5 or 15 deg. to complement the #11(280hp/680tq) plate I'm running The stock cpl is 2175 which is 13. 5 deg. How much of an HP increase can I expect?
Also how much will advancing the timing lower my egt's? Searched the archives and did'nt come up with anything.
Thanks in advance #ad
1997 2500 Ext Cab 4X4,5 spd,Pac brake,Rancho 9000's,Centerforce clutch,K&N airfilter,Missing Cat,Isspro gauges,and #11plate(280hp/680tq)
[This message has been edited by Rebel (edited 11-08-2000). ]
Timing to 15. 5 degrees will give you a definite gain in hp and response. One size fits all performance throws all that timing and custom work a curveball. Not using a new torque plate and setting your pump up to deliver an appropriate fuel curve for your application is our way of doing it. If you have the plate in the engine already, the timing can be set up to accomodate it, but it may take several tries until all things are optimized.
Chris
1997 5sp 4X4, HX40, BD 4" Brake, Marine Compression, Custom Tuned Injection Pump, 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, Water Injection, 6" Chrome Exhaust System, No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc. Test mule for Auto Wurks race program
Last I remember..... It should be around 150-200F cooler.
Hope this helps...
2001 FL70, 330hp CATERPILLAR "3126", I've gone to the dark side... .
<<>>Charles Pyatt<<>
*WARNING this post may offend some ford-diesel.com members*
150-200 deg F cooler..... WOW! #ad
I was starting to lose interest in this modification until now.
Any extra HP gains would be icing on the cake.
Any other experienced opinions on this subject?
1997 2500 Ext Cab 4X4,5 spd,3. 54's,Pac brake,Rancho 9000's,Centerforce clutch,K&N airfilter,Missing Cat,Isspro gauges,and #11plate(280hp/680tq)
How about a gain in mileage. I got between 2 and 5 more mpg upon the initial timing advance I made and that was from 5 Deg. BTDC to 13. 5 Deg. BTDC. I'm now at 15. 5 Deg. BTDC #ad
Chris Timochko
1997 5sp 4X4, HX40, BD 4" Brake, Marine Compression, Custom Tuned Injection Pump, 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, Water Injection, NOS Diesel Kit, 6" Chrome Exhaust System, No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. Test mule for Auto Wurks Diesel race program
FL60cummins, (you'all please forgive the break in the thread subject), what happened to the little FL60 5. 9, last count I had it only had about 300000 on it. Start pulling bigger loads or just decide to try the other folks?
PS, how do you like the Cat?
You can expect 50 lbs. of combustion pressure, and 50 degrees of combustion temp per 1 degree of advance.
This will burn the fuel more completely in the cylinder reducing EGT some, but I would NOT expect 100-150 degrees.
Cummins recommends 14. 5 degrees BTDC for most B-Series engines.
Our experience has shown 14 to 15. 5 seems to work in most applications.
More than that can increase smoke, and definitely increases NOX levels.
There doesn't seem to be much difference from 14 to 16 degrees, but when coming up from 12 or lower it definitely makes a difference.
Ted Jannetty
Ted Jannetty, Owner President, Jannetty Racing Enterprises, Inc.
97 3500 4x4 club cab 5spd. RED, JRE custom power kit, JRE 4" exhaust
JRE 1/2 inch fuel system, Bosch 300 hp injectors, Prime loc,
Cummins chrome kit, US Gear 20% over drive, 3. 54 posi, Autometer
Ultralite 50lb. boost, and Pyrometer, BD exhaust brake.
Horton fan clutch
99 Ski-Doo 800 Formula III Pipes, reeds, studs and clutching 172 hp
99 Honda Forman 450 ES jet kit, pipe, lift kit, 27" Mud Runners
2001 Ski-Doo MXZ 800 X stock for now 140 hp
2000 TransAm Ram Air WS6 Flowmaster, K&N, Granatelli Mass air meter, LS1 Lid 370 hp
1973 Camaro Rally Sport Street Strip 850+ HP
