advancing timming on an 05?
How to use Tow/Haul mode?
04.5-05
is this worth anything? will i get better fuel millage? does it make the engine run smoother? will i get more power?
I put a ROKK tech Crank position sensor on last week, that advances the timing about 2 degrees. So far the power has improved, and so has the mileage. About 1 MPG while towing the fiver. For a 12K fiver, that is a pretty good increase... ... ... Sarge
The install was easy, once the old sensor was removed. The hard part was needing a small box end wrench to use as a lever to slip over the hex key to assist breaking the stock sensor loose. After that, the new one screws in easily. The difference was immediately noticible. Great bomb... ..... Sarge
