Hey all,
I wanted to ask a bit of advice for my brother. He recently retired and upgraded his truck from a 2012 Ram 3/4 ton to a 2020 Ram Limited 3500 SRW HO Aisin Longbed Regular suspension
He upgraded his truck because he is considering either a 5th wheel or truck camper.
I am familiar with the bumper pull trailers (Airstream) but not so much to 5th wheel world.
This is a SRW truck.
5th Wheel questions: non-toyhauler layout
- Is there a buyers guide that shows the differences in quality (5 years old to new)
- Is there certain pin weight that should not be gone over
- Appropriate length, weight ratio for the trucks capabilities
- Best length for state and national parks
- Recommended hitch - truck has the factory puck setup. B&W or some type of hitch with air bag/shock absorber?
- Are air bags typically needed on a 3500 truck with 5th wheel setup?
- Best trailer frame and suspension?
Truck camper questions:
I often check out the threads here in the rv forum. It seems that with a truck camper it is all about the proper center of gravity and weight of course. He may want a truck camper so that he can take a bass boat along on the trip. Is this possible? I assume you could only have an 8' max length camper and do this.
- Brand recommendation?
- Is a camper with a slide too heavy for a SWR truck?
- Best camper tie down system. I have seen the recent picture of the 3500 Ram and broken frame. It seems there were several issues at play to cause the failure.
