Engine/Transmission (1998.5 - 2002) advice needed
Engine/Transmission (1998.5 - 2002) bucking problem who has it?
Engine/Transmission (1998.5 - 2002) Injectors
As my sig says, i have an 02 HO. i am currently running an EZ but i have an opportunity to sell the box to a friend that has an 01. My first question is what is a good source for an adaptor to use the 2002 EZ on a 2001?
I have been reading horror stories about towing heavy with an HO and an EZ so i am thinking about going another route. I can take the money i get from the sale of my EZ and get a set of 75 hp jammer nozzles, a stand alone boost fooler and adjustable elbow. Can anyone with experience with both an EZ and 75 hp injector tell me how the two compare power wise? Also what is a good source for a boost fooler to keep from setting an over boost code? thanks in advance.
blake
I never have had any problem towing with my EZ or my EZ-Comp. 163,000+ and still have the original clutch and brakes. I have 275's installed for injectors. I think if you read the "HORROR STORIES" you will see there is a little more to the problem than what was being told. I tend to think that allot of the individuals that do a power upgrade, think they can now tow using all the power they can generate. Power is nice, but when applied in predigous amounts while towing, thing go bad. I have been to 23,000 lbs on a 10% grade and not had any problems. ;) Most problems are driver induced by too much go-pedal when moderation should be the rule ;)
jammers EZ
Well I have 100 HP jammers and currently have my EZ off the truck. the power is smooth to me it help out with 2100-2300 rpm range smokes a bit but is good I put on a fass fuel pump the same time as the jammers I gained around 100 more mile on the tank driving empty. as far as handling the stock clutch handles the EZ and jammers but I agree you dont need your whole foot to tow. it aint racing its towing. I usually tow 7000lbs to 10000 lbs
as far as the foolers and elbows do a search there are people out there
that has them. good luck hope this helps.
2002 HO 6-SPD LB 4X4 QUAD, WITH BHAF 4" SILVERLINE BD-X MONITOR (PYRO, BOOST)
BW TURN-OVER BALL, RIDE RITE AIR BAGS. EDGE EZ, JAMMER STAGE-3, FASS 95/FLOW PUMP, VULCAN 3/8 FUEL LINE AND FITTINGS, FUEL PRESSURE GAUGE, MOOG TRACK BAR. AND TIE-RODS, EAGLE ALLOYS ON 285'S, COUPLE OF STUPID STICKERS AND DE-BADGED FOR FUEL MILEAGE.
NEXT UP SOUTH BEND CON OFE OR A LUK GOLD AND TST P-MAX 3.
SOON I WILL PICK UP (HEAVY) SMOKING AND I THINK I WILL LIKE THIS HABIT
