I am one of few 12v'rs that have a fuel pressure gage on my truck. I also have the smaller 180hp pump. I am thinking that I would benefit from a FASS or similar system. My signature pretty much describes my truck. It seems like it runs really smoothly through about 2500rpm but becomes rougher at higher rpm's and when towing. I can usually suck the pressure down to 18-20psi on good throttle romps so I'm thinking I'm creating some timing lag. My pump is set at a hair over 16deg.
The three I have looked at are the FASS, AFS from Haisley and the Preporator. Anyone have good/bad experiences with these?
I was also wondering how to set up a system like that: remove the filter and stock lift pump or use the electric system as an additional prime for the stock system?
Thanks.
Thanks.
