Originally posted by Dixie Dawg
Just ordered a set from Sam's offroad. Any tips y'all can provide? Tried searching, didn't provide much. 'Preciate it!
The rear shocks are nearly trivial. Youwill likely have to remove the spare tire to get access to one of the top bolts.
The fronts (on 4x4) can be a pain, but they aren't so bad, either.
- if tossing the old shocks, use a vice grip between the coil spring to hold the shaft, if necessary, so you can remove the top nut.
- Remove the 3 nuts holding the shock tower on the frame; you'll want to do this so that you can get the tower up and off the shock *before* the shock extends!
- Remove the lower mounting bolt.
You can now remove the shock from under the hood. Yes, brake lines almost appear to be in the way, but you can snake the shock past them.
IIRC, I didn't even raise the wheels off the ground. Just rolled under the truck and changed the shocks. But then, I *am* a puny, scrawny 165#; I climbed inside a wall once to do a bit of electrical work.
Pay attention to bolt torque specs. And pay attention to the bolts themselves. If they seem worn or corroded, buy new ones. And lightly coat the bolts with anti-seize; this is mostly to keep the insides from siezing to the shock.
It's really not a hard job. Should take you 1/2 hour to dry-run, i. e. , visually go through the process, 1-1/2 hour to do the change, 1/4 hour for a beer and a smoke, and another half-hour to clean up and put everything away.
Good luck!
Fest3er
