I'm learning how to use my newly fitted BD exhaust brake, and I would be grateful for some advice from experienced users. The Autolock unlocks the torque converter lock-up clutch on decelleration at 28mph, so the exhaust brake has virtually no effect from that point. I assume therefore that on descending a long grade, overdrive off, with a heavy load and a 6500 pound trailer, if there is a sharp bend, perhaps, and my speed drops below 28 mph, I will have to rely on my service brakes for the rest of the descent? This happened yesterday. I tried to speed up a bit to re-lock the TC clutch, but chickened out after a while! My home is at the top of a grade, with bends, so this is relevant to me. I could change into second gear, but the TC will not lock in second, and the exhaust brake will not work, although engine braking would be improved. (and the tansmission fluid will get hot? I have a temp gauge on the transmission output line). Is there a way round this, or should I have bought a stick shift? Thanks. Nick.
