Advice on which switch to buy
Help! They wrecked my truck
New VP-44 Injection Pump Installed
I have installed all of my gages and am stumped on my fuel psi gage, I have senders both pre and post filter and would like to install a switch so I can see both, what do you call that style of switch? double pole double throw ??? Kevin
switch
if you have to switch 2 wires from each sender, double pole/ double throw. if you can switch only one wire from each sender--ie. use a common as in ground, then single pole/double throw. the ones i've seen needed both wires switched, therefore, double--double.
