Engine/Transmission (1998.5 - 2002) aeromotive fuel pump
2nd Gen Non-Engine/Transmission no steering when braking
has anyone had any experience with aeromotive fuel pumps on a cummins?? im thinkin about runnin an aeromotive fuel pump instead of fass!!! pros/cons???
i need a supplement fuel pump so i dont fry my vp. fass systems are way OVERPRICED.
I am.
I first ran it with the 20 micron prefilter, but it would easily plug. (I was running some bio). I just took it out and it has been good for two years total. I ran a walbo until it started to get air in the line. I ended up with the aero pump. I t has a regulator after it (aero too) set at 15. It hold 12-13+ all the time unles the heaters are on. Of course you don't want to throttle heavy until the motor in up to temp anyway.
Been running one for about 3 years now. Run a bypass style reg. and set @ 15psi. WORKS AWESOME!!!!
