AFC adjustment?????
good news
WHO SELLS 215 HP INJECTOR'S?
does anyone know the proper way to adjust the afc???? it appears that the star wheel behind my spring was messed with, looking at the motor it was turned all the way in (counter clockwise) thanks in advance for any help.
94 dodge dually 5. 9L cummins 3. 54 rear-end
If you are standing in front of the truck facing the engine, the wheel has been backed off all of the way which will give you more low rpm fueling. I adjust the afc for a puff of smoke at take off with good acceleration. TST has a kit that allows you to dial in the afc for minimal smoke at low rpm and full travel at max boost. Check the archives for lots of posts too.
1998 2500 Quad Cab, 12V, 5spd, 4x4, HD Transfer Case, 370HP Diamond B Injectors, #4 TST, 16cm2 Housing, AFC Spring Kit, BD Governor Spring Kit and other modifications, Walker Muffler, 285/75-16 BFG AT's, Stainless Steel Tube Steps, Reese Fifth Wheel Hitch, Leather, CD, LSD Dana 80 Rear, 60 Front, Centerforce Dual Friction Clutch, Rancho RS9000 Shocks, Rancho Steering Stabilizer
Thanks Dieselburner for the information. by chance do you know what type of kit this is or what its called???? I dont mean to sound stupid however I am new to diesel's, thanks in advance.
It's the AFC spring kit. You may want to talk to TST first - they say it really helps the 5sp but not the autos! Craig
97 3/4Ton, 2WD, 5SP, #11 Plate, 14 Housing, AF942M Air filter, Gutted Cat, 4"From Turbo, Airlift, Shortened Frame, Custom Bed, HEY FORDBOY POWERSTROKE THIS!
The AFC spring kit DOES help the autos as far as smoke control is concerned. I had to install the med. spring to control smoke. With both the stock and soft springs even a light push on the throttle would produce copious amounts of black smoke. Medium spring produced a good puff of dark grey smoke and lightens up as boost increases, then disappears when boost hits 30 and over.
1996 3500 Clubcab SLT, auto, 4. 10 limited-slip, TST #5, 370s, AFC spring kit, Psycotty, Dunrite converter, Trans-Go, DiPricol EGT, boost & trans temp. gauges, 9 ft. aluminum flatbed and tool boxes with Venco dump. Custom front bumper, Hadley air horn.
