AFC can't open
Potential new 24v Rammer looking for advice - need input
Resonator or Cat?
I put a new plate in my truck and wanted to adjust the star wheel but i can't get the screw top off the AFC. I tried with an allen and oil but it just wont budge. Has anybody else had this problem before and any ideas how I can get in there to adjust the star wheel. I put some serious force on it and it wouldn't budge. Bent the allen wrench pretty good. Thanks
125,000 Miles!
Yes 'mam it is a rolling office/bedroom/pickup/stinkpot/the best truck ever made!
1998. 4 4x4 Quad Cab 2500. 19. 5" Rickerson's White w/gray trim. Jannetty #4 plate, Limo tint ALL Windows, Whistler hidden radar built into overhead dash, Combo toolbox/41gal tank, electric start, Car Alarm, Lund Grill Covers, Electronic Idler, scotty's air intake, K&N Prefilter, Hadley Bulley Air Horns Mounted Bumper Level, Banks Pyro and Boost Gauge on the A-Pillar, transmission upgrade, Blue Chip TC, Valve Body, trans go kit, and and more to come.
They can be tight little SOB's. Use an allen head socket style with a good rachet or breaker bar & watch you don't drive your left elbow into the battery #ad
it smarts
Piers, BD engine R&D
Rap on the top of the plug a few times with a hammer. Then use an 8mm or 5/16" allen bit, extension, and long breaker bar. Or, a long arm allen wrench and a long cheater on it.
All I had was an allen wrench, so I slipped a small pipe over it. I thought for sure it would break it, but it did come off.
Eric
A small amount of heat (careful) generally helps to break bolts loose. The aluminum pump will have a higher thermal expansion than the steel plug. Have you tried it with the engine hot?
95 Ford F-350 4x4 Ext Cab, Cummins 6CTAA 8. 3, Fuller 9 Speed, Big Rig Heart in a Pick-up Truck
