Hello,
I have recently installed a TST #8 plate in my truck. I have been "messing" :-laf with the position of the plate, AFC star wheel, and housing cover position. I was wondering if someone could give me an explanation of the relationship to each other, and each parts actual purpose. I understand the plate to be a full movement stop. Does this mean the plate only affects full throttle? I have adjusted the star wheel to its fullest extent forward. I know the AFC cover is sensing boost pressure, and therefore richening the fuel. My question for the cover is, forward or backward???? The TST instructions recommend all the way back... . but they also say put the new plate in exactly the same position as the stock!
Does the arm move forward when boost pressure is applied to the internal diaphragm; and is this what contacts the new TST Plate? The truck doesn't seem any different with the plate and wheel fully forward. The smoke is still very minimal, and the gains are not noticeable.
Thank you very much for reading my rambling, any info would be appreciated!
