I've adjusted the preload screw on the back of the AFC housing several times and finally have it running good(about 5 turns in from when it first makes contact); reasonable power from a dead stop and tons of power when the boost gets to about 10-12psi. I'm not sure i like all the smoke i'm getting as it's almost impossible to start off without leaving a black cloud behind me. If i turn the star wheel back a bit (it's full forward now) will i loose low end power? Will it get rid of some of the smoke? Any suggestions to Clear The Air a bit?
Thanks!
Brian
Thanks!
Brian
