The AFC has two controls, spring and boost pressure. The Boost pressurizes a diaphragm which has some resistance placed on it by the spring. tightening the spring causes the afc to require more boost to displace the afc foot the same distance. loosening the spring does the opposite.
I personally dont think the afc can come out of adjustment where it would cause more fueling. the only failures I can think of would relate to less fueling. It sounds to me like its not an AFC problem, but a boost leak somewhere, or maybe a wastegate that is partially stuck open and allowing the exhaust energy to bypass the turbine for a while.
Do you have a boost gauge??
--Jeff
