re: hdm's comments on spring progressive spring rates... . Can we follow this along a little further...
First is there any merit in considering the alteration of this component at all?
Since the starwheel itself is, in effect, a spring adjustment specifically designed to do that job ( as I understand it's function) Would making physical changes to the spring itself be a redundant change?
I can envision how a "progressive" spring would work in terms of resistance increasing with deflection, but not the other way round. Unless the aim is to set the starwheel low to have a quick onset of fueling and then the progressive nature of the spring causing a slowing of the rate as the AFC dropped, needing higher boost, what other purpose would this serve? If this was the aim of the change, then would you not serve the same purpose by easing the starwheel back up, then increasing 'full fueling' (keeping in mind that this adjustment directs a larger portion of the total fuel increase to the low/mid range) which would result in heavier initial fueling (like the low starwheel setting) and then have the stiffer starwheel setting slow the travel rate due to being set higher?
(No one has mentioned delivery valves on our pumps either... )
Would there be any theoretical benefit to lowering the starwheel all the way down and using a progressive spring for the entire AFC deflection control function?
Also, when I was trying to get my smoke screw to a true "neutral setting", that is, absolutely no pressure on the AFC, I found I had to back the screw right up into the housing body. Then, take a dremmel with a 3/16ths round fine stone, and grind away some of the inside casting were the smoke screw protruded from. Even at that there is still a slight pressure on the AFC from the screw end/nut in the center of the AFC diaphram since I assume its contacting the underside of the smoke screw housing outlet.
I did notice that my "witness mark" on the cone showed that the fuel pin was reaching a little lower on the cone when at idle condition.
One last thought, ... is there any difference as to were the boost tube draws its boost pressure? Would drawing boost from say, the inlet horn instead of the manifold make any difference in response?
Ok, that's alot of thinking out loud. Does someone want to pick at it and scrap the none issues and work on the applicable ones???
Bob
