My findings
Ok here ya go .
In valet mode i get about 15 to 20 lbs of boost max.
normal driving moderate 1/2 to 3/4 throttle nets about 10 psi.
In go go mode (no valet) She pumps out 36 psi. yeee haaaa
I went one step further and installed an indicator light that signals at 7 psi. I used to call this economy mode.
The light only comes on if in valet mode.
When the valet (go-go mode) is off the indicator light does not work.
Any way here's the finding's... .
Set -up.
3k gsk , Banks plate full forward, afc totally loose,gov. arm adj,14cm wastegated,15. 5 timing, non egr, no kitty,afe filter.
about 350 hp?
I have driven mixed hwy /city and kept it below 7 psi.
I get the same mileage in valet mode driving it hard peddle to the metal.
The engine seems happiest and best milage when driven at 10 or 12 psi.
So I just bring the boost up to 10 or 12 untill I reach crusing speed at 70 mph
So this tells me keeping the boost down on my combination of bombs only manages to be no fun to drive.
I have found it's most enjoyable to drive in Go-Go mode and just go easy on the go peddle.
End up getting the same milege and it keeps the grin going. '
However the mileage goes down the tubes when driven hard without the valet on . Full booost with enough black smoke to make the EPA cry. . Yeeee Haaaa
So if you just can't controll your right foot a Valet switch might be for you.
Valet mode is just that "VALET".
Use it in the snow ,use it when someone else needs to drive,
Use it to save a worn out trans,
P. S. Valet switches are fun too.
Take off in valet mode WFO... .
Then at about 50 or 60 keeping it WFO turn the valet off and hang on!
SFB
