AFE drop-in filter
Warning Rip Off
Will Auto transmission Hold Up?
I'm not looking to start any wars. Considering drop-in filters I mostly read about K/N drop-in filters pros & cons. I would like to get some pros & cons on the AFE drop-in. Like does it fit good in the factory air box or anything else you guys could add.
Thanks,
Eric
The AFE drop in is a very high quality air filter, nice framework and rigid filtration media
I ran one as a test
the AFE systems are great. Their install is simple and there is no drilling or modifications that are needed in order for them to fit. They are a great product.
I have the drop in AFE. It seals great in the oem airbox. One side on my filter that has the metal grate pulled out of the rubber, but doesnt affect the sealing in the box. I cleaned mine the other day & put the stock back in to let the AFE dry & noticed the turbo sound was almost non-existant compared to the AFE. My egts were also around 50° hotter with the stock filter.
Thanks for all the replies guys. I guess one of the main things that make me nervous with these filters is me. :-laf Is hard to screw up on cleaning the dern thing? Mainly oiling, too much or not enough.
Thanks again
Eric
Not trying to start a war or argue but I must point out a few things.
I disagree with Mark on the over oiling.
The ISB engines in our Dodge rams also use a mass air flow sensor. Also in the air stream is a Air Intake sensor, either one could be screwed up by oil on them and send wrong signals to the ECM.
Oil on the inside of the intercooler is also not a good thing, air to air cooling would be compromised considerably if enough oil coated the inside of the intercooler.
Ron
Mark,
You sound like marketing tactics to me.
I never said fill the intercooler with oil. A film of oil on the inside will impead what the intercooler was put on our trucks for in the first place.
Secondly, Make a search on the TDR and you will find guys who have had sensor problems due to debrie on the sensors. I was one of them, although it came from a K&N filter and was probably due to me over oiling it, the problem still exists from over oiling an oil type air filter, guys have reported filters direct from the factory that were over oiled. I also experienced gunk on the turbo blades. Since I have removed the reuseable type filters I have not had to replace a sensor or have I seen gunk on the turbo blades, the same as before I used the reusable oil type of air filters.
With that being said I think some of the reuseable types are fine filters as long as they are properly used for their specific application and maintained properly.
All this is from my personal experience and other members here on the TDR. Use the information as one wishes, I know what type of filter I will continue to use in the future.
Ron
Didn't Cummins release something about not recommending people use oil type filters? Specifically because of turbo related failures due to debris collecting on the fins?
Mark,
Thanks for clearing that up.
Just trying to level the playing field by letting people know problems can and do exist for varying conditions.
Ron
