afe+high flow muffler = turbo bark?
just bought an 06
Power adjustable pedals
i installed an afe stage II last month and i noticed the turbo spooled up quicker, last week i had a straight through high flow muffler inplace of the stock one and now the turbo spools up even faster. last night heading down the onramp i was going from 4th to 5th and when i pushed in the clutch i heard a noise and the boost gauge dropped really quick. when i had it in 5th and let the clutch out every thing seamed fine, just between shifting i heard the noise from up under the hood. next up grade a new turbo? is the stock turbo, to small for lack of a better word. sure seams to wind up real quick now. everything on the engine is stock but intake and exhaust. one more thing. if i upgrade the turbo to a edge jammer or sps 62 or the like, should i get new injectors or will the stock ones be ok with the extra needed fuel?
You can feel that little turbo in the floor boards when you bark it at 40+PSI :)
if you get your self a bigger turbo, you will for sure need a a box or 2 to manager all that air better.
