AFE Intake Manifold
AMSOil bypass filter kit for 6.7L
Why doesn't someone build a 12v lift pump?
I finally got enough time to take a few pics of the new AFE intake manifold. The dipstick tube mounting is not stock set-up. I had to add the bracket due to the Carli shock tower brace. (Got to have a stiff front end :-laf)On stock applications it is a direct mount just like OEM.
Bob
i couldnt find it on their web site ( i could have easily just missed it) do you have a link to it?
Sorry I should have said mine is a pre production piece,I haven't heard the release date yet. I did see the artwork on the boxes they will be shipped in so hopefully it will be soon. I will be camping with the AFE crew next week end so I will ask then.
Bob
Dyno test,stock fueling,air flow improvements only. AFE stg2 ans AFE cat back2nd gear 15k simulated load,37" Toyo Mt's
Bob
ooh... pretty :D:D:D
is there pre drilled holes for boost, n2o, h2o, ??? [or at least a heavy casting section for drilling & tapping yourself]
any news on other available colors? [i want blue]
There are holes pre tapped,and more built up bosses for the crazzies that need it all I have a pdf file with more info at home I will try to post when I get a lil more time.
Black is the color offered:-laf. On my 2nd gen I got carried away with chrome and blue,the 3rd gen will remain simple... ... ... ... . black.
Bob
Hey Bob. Very attractive piece. AFE has a nice looking, and what appears to be functional design, as dyno looks good too. Is it aluminum cast? Could be polished up and clear coated or custom powder coated too. Directional vanes would help the air flow/velocity, but like all the other intake horns it still becomes restricted because of the inlet/outlet sizes. Nice.
CD
Yup. cast aluminum,2 pre tapped holes and 3 more bosses. Inovative bolt design and no worries about high boost with race twin turbo set ups running extreme boost.
Bob
I towed the trailer out to Pismo beach a couple weeks back,it was a noticable differance in how it pulled the at lower rpm up the grades. I averaged 15mpg at speeds between 55-75 depending on traffic.
No pics of the inside... ... ... . to busy to spend the time to tear it off,so many projects so little time.
Bob
I hope it performs better than their high dollar new Pro-Dry S dry filters or it will also become a garage dust collector..... Andy
