Hello TDR brothers and sisters
I have been off the grid for a while
I am back up and on line again
After much nashing of teeth and back and forth and unexpected monetary out put I have decided to keep my 99 CTD for a while longer, as opposed to truck payments I have decided to up grade some of my weak points with the truck that I have not already dealt with.
Aftermarket Radiator.
after pulling in hot weather and my truck running hotter than normal I am going to pull my Radiator and completley clean the exterior. should this not be the case I have been expolring the idea of an after Market radiator.
SO comments opnions and suggestions are welcome.
Secondly Stainless steel brake lines.
I live in a cold very wet salty air environment after reading posts of popped brake lines i have decided to do to things this winter new Stainless brake lines and try to improve my rear braking ie disc brake conversion and or some type of drum upgrade or a replacement rear axel with factory disc brakes.
thank you in advance
Chris Olson
Chris Olson
