I’m beginning my education on the 12V engines. My first question is to aftercool or not? I assume the aftercooled version is a better engine. Will the aftercooler complicate the conversion? I hope to use the original radiator by converting it to a pressure system. I am not opposed to a custom radiator if necessary.
I know there have been many previous posts about putting a Cummins in a Power Wagon. I think the 4bt is the most practical option. I know there are lots of 6bt daydreamers out there. Since daydreaming is fun and free, I submit the following:
I was measuring my Power Wagon, and came up with these options. If you built a custom radiator, you could move it forward in the radiator shell about 4 inches without changing the outward profile of the hood. This may not work if you have a winch. You could move the radiator another ½-inch by thinning the horizontal grill bars so they are not much deeper than the vertical grill rods. This would give you 34-1/2 inches from firewall to radiator, assuming your custom radiator is the same thickness as original. Unfortunately, by putting the radiator directly behind the grill, we eliminated any space for an electric fan. The later Power Wagons with the 251 cu. In. flathead had a grill that was moved a few inches forward to accommodate the longer engine. Combining these features might get you enough clearance without dog-housing the firewall.
I digitally modified a couple photos of my Power Wagon to see what it would look like with a stretched wheelbase and longer hood. You can compare photos at http://imageevent.com/shaggy/trucks I really like the results. It has the proportions of the 3-ton Burma Dodges.
My budget for parts necessitates that I’ll have several years to plan and perfect such a scheme before any butchery begins.
