Aftermarket Box
BOMBed NV-4500 or 1-3/8" equipped NV-5600?
Turbo break-in
This is my first CTD and am looking for honest opinions regarding "boxes" for my truck. This truck is will be my daily driver and will also tow a 38' 6K(dry and unloaded)LQ GN 14-20 times a year. I am mainly interested in something that is driver adjustable from the cab, won't smoke like a train , and doesn't "throw" codes. Not necessarily looking for max HP, as this is my daily transportation. Truck right now is bone stock. Any thoughts appreciated. Have seen many posts regarding boxes, but almost all trucks using them are slightly to highly modified. Most I plan on doing is adding gages, filter, maybe trans pan, and diff cover.
Thanks,
Mark
Edge Comp if you want adjustability with power *and* smoke. And if you don't want to tap the pump then it is the same as a EZ.
This is a 600 guys the EZ doesnt work correctly with it and will throw codes and the edge comp (now called the juice) isnt available and probably wont ever be available. Check out Dleno box comparison chart (do a search for it using those keywords) And that will give you all the info and functions of each box.
