Aftermarket Liftpump ??
Hard Starting Update
Rear ABS Sensor
Hi fellas, does anyone know if the lift pump in our first gens. are an inherent weak link?
Does anyone make an aftermarket replacement thats of good quality?
thanks in advance!!
Regards, Bush'
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar,Dual Shock Front Stabilizer,BD Injectors,31/2" Mandrel bent exhaust,16cm 'Hot End',Modest Pump Tweaks/Timed,K&N Air,Isspro Pyro,Tach,transmission Temp,Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots. 97,000 Kms.
I purchased an Airtex brand pump and the quality was terrible, especially in the threaded fitting area. I ended up returning the pump tp the auto parts store and visiting my Dodge dealer for a quality replacement part.
'93, W250, 4X4, Autometer boost and EGT gauges (in the dash)
Go to your local Cummins distributor--it is a Cummins part and is used in many engine applications besides Dodge where the fuel tanks are located below the engine.
Bill
Y2K 3500QC, 6 Speed, 4. 10, SLT+, Camper & Tow Pkg. , Westin Chrome Nerf Bars, Mopar Flaps, Reese 20K Hitch, EGT & Boost Gauges, RPM 45 Gallon Aux. Fuel Tank, Highway Products 5th Wheel Toolbox, ECM Controlled PacBrake, Painless Wiring Kit, Mag-Hytec Diff. Cover, Rancho 9000, Air Lift 5000 Air Bags, TOYS: '97 Hitchhiker II 31' 5th Wheel, 2 slideouts, 19,750 GCW, '94 Lance 990 11' 3" Slide-In Camper, Torque-Lift Camper Tiedowns
I got mine at Los Angeles Freightliner.
As a matter of fact I also got my front seal there too. A little cheaper than Cummins and the parts and service department is open 24 hours a day! If you have some big rig dealer nearby give them a call. The parts I got were genuine Cummins.
'93 W350 Club Cab, Bright White, 5 sp. , 136K, Factory Options: LE package, 4. 10 Limited Slip, 7600 lb. rear springs, tachometer, front stabilizer bar. Mods: Banks stinger plus, Linex bedliner, 25,000 lb gooseneck ball, 10,000 lb receiver, Tekonsha brake controller, POWER WAGON injectors-WAY faster than stock!.
Unless you have an obvious leak, and have only a hard start condition. Check the overflow valve its on the left front (facing engine) of the fuel pump. The overflow valve is in the return line fitting. The spring has a tendency to become compressed. You can remove it and disassemble it and stretch the spring out to . 500-. 550. Be careful when you take this thing off the pump as you can lose parts down in there. I was told to cram a towel down in there to catch the parts. You don't want to lose the parts that go to this thing because it costs about $60. 00-$80. 00. After you take it off you will figure outhow to put the valve back in one piece.
I hope this is of some help.
D McGrady 1996 Club Cab 6BTA 5. 9 12 Valve All Stock Except K&N and Wrangler A/T 305/70/16 136 K and going strong.
Excellent! I'll also pass this along to my younger brother.
Thankyou again!!!
