2nd Gen Non-Engine/Transmission Aftermarket radio install, with issues!
Engine/Transmission (1994 - 1998) I think I screwed up
Engine/Transmission (1998.5 - 2002) Costal Oil
Ok installed my alpine in my truck today, all went well, but i have no sound out of the door speakers in cd or changer mode, but it will work on the fm mode just fine. I can hear the music through my subs on cd/changer mode but thats it. Radio worked fine in last truck. I doe hear a clickin(relay) noise in the dash when going from cd/changer to fm mode and back but can not pin point it. It is not coming from the deck.
yup it is working, amp comes on and plays sound but will not play through the door speakers on cd/changer mode but everything will work fine on fm mode.
its not your deck its the self amplified door speakers. if your running an amp to the front and rear buy a new pair of fronts and wire dirrectly to them. also the factory 6x9's control the tweeters on infinity system. so if you get new 6x9's you'll have to get crossovers for the tweeters
Ok i got it, i had the power ant hooked up to the factory amp and it was turning it off going to cd/changer mode, now i hooked it up to the amp turn on lead and wahlaa! Thanks for the help.
