I just took the broken tape deck out of my '97 standard cab, and ordered a really cool CD head unit from Crutchfield. It plays regular CDs, as well as MP3's burned to CDR or CDRW. It's possible to get 10-12 full CD's on a single disk with MP3 compression.
I have a problem with the speakers, and am hoping that you guys with trick stereos can help.
I got Polk Audio 6 1/2" coaxial units for the doors, and for behind the rear seats, at the recommendation of Crutchfield. I'm not impressed at all. I think having tweeters behind the seats is a waste, and am thinking of a 8" or 6" seperate - mostly for bass.
I'm also thinking of 6" or 8" separates in the doors, and tweeters in the doors where the factory Infinity units would go. Mine doesn't have the Infinity option, but there are holes in the doors (not in the door panels).
I have 40 watts per channel in the head unit, and the cab is smaller than my Pathfinder which has a similar quantity of power, and sounds fine. I can add a powered sub if I have to, but I'm trying to not throw too much more money at it, so I can spend it on BOMBing.
Any tips on what fits with minimal messing around? I don't mind cutting into the metal make something larger fit, but don't want to go nuts either.
I'm not trying to build a show truck, or a Honda that you can hear at the end of the block, or to spend thousands. I just want something that sounds clean at reasonable volume levels.
Thanks for any ideas.
Tackett
'97 2500 4x4, auto, stock at this point, but adding goodies as fast as I can.
[This message has been edited by Tackett (edited 10-30-2000). ]
Tackett
