Engine/Transmission (1998.5 - 2002) Aftermarket Tach...?
2nd Gen Non-Engine/Transmission arm rest
Engine/Transmission (1998.5 - 2002) 98.5 or 99
So has anyone put one on? Where did you tap into the signal?
Anyone know what type of signal the CPS puts out? I would like to tap into that to run the tach.
Andrew
I used an "O" Scope from work a few weeks ago and took a look at things.
I found a wire that I thought would work, but no dice. (I also scoped a few "other" things prior to my last dyno run to make sure I was..... oh nevermind)
I think the best bet is a magnetic pickup off the harmonic ballancer.
Originally posted by TxDieselKid
So what type os signal DID it put off from the cps? Was it on a ratio? A ratio will work out great!:D
it was about 250 HZ at idle with a peak voltage of 5 V.
it was a grey black wire on the plug on the firewall above the fuel filter.
the grey black wire on the PCM (Plug C1, PIN 8 on the PCM) was only 2. 5 volts
