Details here: TDR Privileges
I've got a pair of adjustable lower control arms and track bar conversion kit along with adjustable track bar from Solid Steel Industrial Manufacturing Ltd. You can check out their products at: Solid Steel. biz
I had been experiencing a lot of trouble with the front end being extremely sensitive to less than absolutely perfect wheel balance setting the truck shaking. Replacing the lower control arms calmed that right back down. The track bar conversion solved the wander our 4x4 trucks are famous for with the factory ball-joint setup. Solid Steel also produces the DSS to take the slack out of the steering gear output shaft bearings which also improves the wander issue.
