Forged wheels and hydraformed wheels ARE stronger than cast. The grain structure of the aluminum is MUCH denser in the forged wheels than with cast. Also, hit a curb head on at speed with a forged wheel and a cast wheel, the forged wheel will bend, usually retaining the tire whereas, the cast wheel WILL break, fracturing to the point of tire separation from the wheel. If you want THE STRONGEST wheel on the market (regardless of advertised claims), purchase the M/T Alcoa Challengers or Classics (not the new Classic IIs... they are cast). Although not as strong, the Weld wheels for our application are also a very good wheel. The Weld wheels are not forged, instead, they are fabricated of 2-pieces of hydraformed aluminum (from rolled sheet stock), fusion welded together in the center periphery of the hub area (unnoticeable when the tire is mounted). The two wheel halves are constructed of a front half consisting of a hub and a rear half which is more or less a mirror image of the front half (not a wheel and hub as is the case of most steel wheels). Both the M/T Alcoa and Weld wheels are excellent choices as well as the forged wheels from Alcoa (although, they usually don't have the width sizes preferred by us Rammers).
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, '00 Sport grille, '00 Sport headlights with PIAA Super White 9007/9004 bulbs, 4-2-7+4 Brite-Box, PIAA Dual Sport 900 auxiliary lights, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, BLACK '00 valve cover, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, plus many other trick modifications
