jsimpson, Sounds like it might be possible to remove a leaf or two, but I have yet to see it done. With my 4K lb. load onboard, my truck sits level. But handling is much better with around 60 psi in the bags. If I were to remove any leafs, I'm sure the truck would go negative in the rear, & if I lost an air bag on the road, it might cause a drivability problem.
RonL
98 3500 QC 4X4 Int Blue, Unbombed 6BTA5. 9 12V,
Auto 3. 54 LSD, PIAA Pro90's, Tonneau, Running Boards, 5K Air Bags, Hadley Air Horns, EGT/Boost/transmission Temp Gauges, Cobra / K40, Valley class V, Bugflector II, Bedliner, Tow Hooks, Cup Smoothie, Meg's turn-down tip, SS Fender Flares... .....
99 Lance 1110 Slide-On Truck Camper
