Originally posted by nickleinonen
i'd be interested in a air brake parking brake... ...
a small brake chamber [type 9"] that actuates a disc/caliper setup on the rear pinion or t-case / trans output shaft. it could work very well. .
Originally posted by HoleshotHolset
I had a brain fart before and came up with an idea.
I was thinking of hooking up an air brake actuator in my truck... . not for the brakes... but just for the noise!
Imagine hooking the actuator to an electric solenoid... . that way... every time you hit and then release the brakes... the actuator moves and makes that 'big truck' racket.
I also wanted to install a 'maxi-brake' pull lever on my dash... . And don't forget the pressure relief valve... . also for more 'big truck' racket... .
Imagine pulling up to a truck stop to get fuel..... you let off the brakes... . the actuator makes all kinda of noise... . and then you pull the lever for your 'maxi-brakes' / pressure relief valve setup.....
Tell me this wouldn't turn a few heads.....
My idea is now out there... ... I can only hope someone does it... . I think it would be pretty cool.
Matt
Matt
Originally posted by MarkF
Nick
You could accoplish that with a line lock. Summit and others sell line locks, or sometimes called roll control. It is simply a valve plumbed in to your brakes with a 12 volt solenoid to actuate it. You tie it in to the front breaks. To use it you just press the breaks enough to keep the truck still, flip the switch and the line lock holds hydraulic pressure to the calipers and keeps the truck still. The downside is they are only intended to be used for short intervals, around five minutes. The solenoids will overheat. These things are popular with the drag race crowd to lock the front wheels and spin the rears without burning up brakes. I have a mechanical version of this in my Jeep, but to do that you have to plumb brake lines up under the dash. Thats ok for a CJ but wouldn't want to do it in my Dodge.
Mattyou should really cosider your big rig racket set up for that yellow thing of yours that runs on diesel. Now that would turn some heads!
Nick
