I have an AC question, in one of my previous post I had mentioned my AC has not been working properly now for two years. I have brought the truck to my mechanic and he and I have tried several different solutions but nothing has worked. AC pressure is fine. I have changed the pressure switch 2x, changed the thermistor on the evaporator, changed the AC clutch relay, changed the power distribution center.
As it turns out the AC clutch relay is not getting a ground signal. If I temporarily ground the relay the AC will work, sometimes it will stay working for several minutes. Then other times it won't.
My question, if I were to put in a switch and manually ground the AC relay when I need AC will I do damage to my system? I don't want another summer with no AC. Since no one can fix my system I don't know what else I can do. I am just afraid since when I manually ground the relay the pressure switch and all other system controls will be bypassed and then the compressor will run constantly until I turn the switch off. Will the system over pressurize, will anything burst, will the compressor burn out? I know my fuel economy will suffer but I could deal with that just to stay cool.
I thank all who reply.
