Since these problems just started??? My guess is the compressor is going off on the low pressure switch. Meaning your system is probably low on refrigerant. However, if your condenser coil is clogged with bugs or whatever it may be going off on the high pressure switch. Clean the condenser with a good degreaser and rinse out w/garden hose pressure. Then try it. If same situation continues, get it to someone that can check the refrigerant system for you.
