Air conditioning compressor electrical connector
Aisin Transmission Poor Quality OMG did I make a mistake if correct
Exhaust brake gauge
larryq
Hello @ all!
I am hunting down an elusive electrical gremlin, and I think I may have finally found it!!
I have a 2010 6.7 and was in the process of checking and putting dilectric grease on all connectors and when I went under the truck I found that the a/c clutch wiring harness is loose.
I can easily slide the connector in and out, but not nearly enough to remove it.
In fact I have no idea how to get it to release at all as it is barely touchable from under the truck, and impossible to get to from the top.
So I have two questions.
1) How do I disconnect the connector to be able to apply dilectric grease.
2) how can I tighten the connector so as to remove the slip in it.
Thanks!!
LarryQ
