Supply Air Temps
Per the '03 service manual, the system is designed for a leaving air temp, (supply air temp) @ diffusers of 45*F. Gone are the days of 38-40*F air, although my '03 does get close to 40*.
Suction pressure should correspond with refrigerant temp in the evap which should be 7-10*F colder than actual leaving air temp. Head pressure runs a little higher than R-12 @ any given ambient. Depending on design criteria of the condenser, (20* delta is +/- is "normal"), you take entering air temp @ condenser, add 20*F, go to head gauge and read temp, then read directly to pressure. Your needle should be right there. There are variations on automotive applications though. It depends greatly on what the radiator fan is doing. If it's just spinning, expect the head to be somewhat higher than you calculated. If the fan is engaged, head will be lower. Clear as mud, eh? Hope I didn't confuse you too much. Ron
