Now that summer is almost here in the Rocky Mountains I fired up the A/C in my truck. It would cool down some but not like it had in the past.
I added 1 can of R134a it helped but the compressor would not cycle on and off, just ran all the time. I put gages on the high and low sides, 35 psi low side and 175 psi high side, while on max air and fan on high. Now here is where it acts up, I had my wife turn the A/C off and watched the pressures, the high would start to drop down to 75 psi while the low would climb up to 75 psi as if they were equalizing, is this normal?
If I would wait for a minute or so and have my wife turn the A/C back on, I would hear a shudder comming from the high pressure hose and notice a vapor spray comming from the back of the compressor.
I probably need a new compressor but wanted to ask the menbers on TDR if these are symptoms of a bad compressor before I spend the bucks for one.
Thanks in advance
Chuck
Thanks in advance
Chuck
