Hopefully they replaced the drier and expansion valve along with the compressor....
Check to make sure your air inlet is not restricted with debris. Also you could remove the blower fan and look in at the evaporator to see if it is caked up with dirt. Does the evaporator drain moisture out properly?
Some people are installing a gate valve at the heat exchanger to keep hot water from circulating in the heat exchanger while using the A/C. I have not needed to do so because I live in a temperate climate, but it seems like an effective idea. That being said, you should first make sure that your AC is operating to specs.
Hi, I just had my truck AC tested to see if the AC needed to be recharged since the truck is almost seven years old. According to the service garage not a Ram dealer the AC does meet the factory specs for AC operation but when it is really humid and hot out the truck does not seem to cool fast enough. I know a Mega Cab will take longer to cool down but the DW does complain once in awhile. What I found out to do is run the AC in the in-cab recirculation mode instead of drawing in fresh air from the outside. This seems to cool faster and makes the cab cooler than using the fresh air intake for the AC.
Do you run your truck in the recirculation mode when needed? If not try this and see if this works better.
Jim W.
Are there any tricks to getting it to work better? I seem to remember something about a tweak to a door?
See post #4 above.
The drier is an important piece of the a/c system in that it has a desiccant bag to trap any moisture that is in the system. It has an end of service life and that is generally about as long as your compressor lasts. Your desiccant bag may well be saturated and not able to remove the moisture that was introduced when the shop opened the system up, especially if they did a half *** job pulling vacuum on it. Moisture causes corrosion, and corrosion will eat everything in the system from the inside out. The drier and expansion valve are cheap compared to doing the job over again and should be done every time a compressor is replaced. I'm also betting money your warranty is now voided since the drier was not replaced at the same time.
X2 ... what he said !The drier is an important piece of the a/c system in that it has a desiccant bag to trap any moisture that is in the system. It has an end of service life and that is generally about as long as your compressor lasts. Your desiccant bag may well be saturated and not able to remove the moisture that was introduced when the shop opened the system up, especially if they did a half *** job pulling vacuum on it. Moisture causes corrosion, and corrosion will eat everything in the system from the inside out. The drier and expansion valve are cheap compared to doing the job over again and should be done every time a compressor is replaced. I'm also betting money your warranty is now voided since the drier was not replaced at the same time.
I don't think you can do that on the 6.7 like you can a 5.9. Been researching it and most people doing this have 5.9s.
Yes you can, I researched this last year. I'll try and find the post later today. It will NOT starve the coolant flow thru the transmission cooler or egr cooler.
If that were the case a plugged heater core would disrupt the other components if you think about it......
You can do it on any of the trucks just so long as it does NOT have water cooled turbo.
I thought that I had worked that out as well. I am booked solid until the first of the week, after that I will go find that post. I had the Cummins block water flow diagrams and everything in it.
Mike.
