I installed an Air Dog 150 with a Draw Straw V returning fuel to the factory fuel suction straw using a dorman adapter for 1/2" lines. Problem is that when I finally got my X-monitor fuel pressure gauage hooked up, w/ a T in the line, I am showing pressure from 32-36 lbs. The unit is suppose to be set at 15 lbs from the factory and they included an extra spring in the kit. Did I miss read the instructions and need to change the spring in the return line or does anyone have other ideas? Am I going to hurt the pump with higher pressure?Thanks.
