Archived Air Dog... need help
Archived 47re Transmission Problem
Archived Stub shaft problems 3rd time
Can anyone tell me where the OE fuel pump lead from the ECM connection is. I cannot find anything that remotely looks like something the connector from the Air Dog is suppose to plug into.
It's been a while since I installed mine, but if I'm not mistaken, the connector you need is attached to the lift pump. Just unplug and connect it to the Airdog harness.
Hope this helps.
mishkaya
Yep, I just walked in here to have everyone disregard. My dumb ***** didn't see the little 2 pin connector, I was looking at the big fuse link.
Thanks
Well I feel a little better but I too had the service manual. Oh well, it's on and everything is good now.
Thanks again.
Ok I give up, where is this connection? I have looked everywhere, I have never had to replace a lift pump but I have looked for every connection possible. Is it hiding below the fuel filter? Behind the fuel heater? Maybe I'm just to aggrivated to see it.
If I recall correctly, the lift pump is somewhat below the fuel filter location and towards the firewall. You should be able to determine the appropriate connector from the one on the AirDog. Hope this helps.
Mishkaya
I think you're looking for the plug on the back of the fuel filter towards the top. It's hard to see an get too because it faces the firewall.
