Air Dog
AFE Pro-Guard 7 Replacement Filter ??
Greetings,I recently purchased an air dog, is it neccessary to connect at the
at the tank or can you splice into tank suction line in a easier location? Thanks in advance 6.
If you bought the Airdog to get the best fuel delivery solution, then don't sell yourself short by compromising the installation. Granted the stock supply line fitting is a bit challenging to remove, but well worth it. You have all the parts in the kit to do the job right. Do the job right, you won't regret it.
Remove the left rear tire. Reach over the frame with your right hand and pinch the plastic ears. Pull the hose off with your left hand. It may help to have your wife or some one pull the hose off for you.
The rest is easy.
